Hello new to the forum I did a search but did not see an answer. I'm trouble shooting a no start issue on a Ford 3600, I can jump the solenoid over and turn the tractor over. I have found that the fusible link that comes out of the wire loom by the solenoid is not connected to anything it must of burned off.
Where does this go, I think I may have to remove the starter and solenoid to bet better look?
Currently my wiring looks like this.
Ignition switch is 4 post - 2 wires go to alternator, the neutral safety goes to the blade connector on solenoid and the 4th wire I do not know. I'm guessing it might be that fusible link, I would have to strip some insulation back to ohm it to test.
I also and not getting voltage back at the switch or alternator so that makes me think more that it is a use some where.
Thank you for the help
