Ford 3550 pto?
   / Ford 3550 pto? #1
Kenneth S
San Antonio, Texas
1965 Massey Ferguson 2135 Industrial. 1967 Massey Ferguson 135. 1996 New Holland/Ford 6640
I've been thinking about going to look at a Ford 3550 industrial tractor with a front end loader, and 3 point hookup (no shuttle shift) 3 speed with hi, and low range, and no pto. I've seen some pictures of the tractor, and where the pto shaft normally comes out it has a plate blocking it off. Now for the $10,000 question, is it possible to put a pto shaft in it without having to a lot of major changes like changing the whole transmission case/internals. Could the transmission that's in it have a shaft for a pto already in it, but you just need to add the coupler, and output shaft along with the lever/shift fork mechanism to engage the coupler for the pto. Since it doesn't have a pto shaft now I know it has a single stage clutch, but I can just use a over run clutch just so I can run a shredder behind it. I'm not afraid of doing the mechanical work side of it, but rather afraid of the cost if I have to get more than the output shaft components, coupler, and shifting mechanism.
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2016 Ford F-450 Crew Cab Kanpheide Service Truck (A49461)
2016 Ford F-450...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
197390 (A50459)
197390 (A50459)
