ford 3500 industrialhow
   / ford 3500 industrialhow #1
wilsonfarm09
graham nc.
massef fergson grah
some help please a friend has a 3500 ford industrial tractor what is the difference between it and 3600 farm tractor dose the 3500 have 3 point hitch and draft control pto explane the difference i know nothing about industrial tractors except that they are yellow he has offered to sell it to me i want to know if i can use it to farm with thanks
   / ford 3500 industrialhow #2
Look for a number on the flat of the bellhousing just behind the starter. It should have six digits. If the fifth from the left is not a "3," you won't want it for ag use. A 3 means live pto. The code would be something like C1023C. This link shows all the detail for interpreting the code:
FORD CODES and SERIAL NUMBERS
The front axle on the industrial tractors is very low to the ground and would not make it very good for row crop work. They're fine for cutting, ground engagement work, loader work IF they have live pto/draft control. It wouldn't be cost effective to try to convert one for this purpose.
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
