Ford 3400 & 4400 diesel generator voltage output at battery. NOT battery's voltage!
   / Ford 3400 & 4400 diesel generator voltage output at battery. NOT battery's voltage! #1
ASBURYFARMER
Freedom Twp, Ohio
Ford/4400 & 3400
I'm having trouble getting a good voltage output when checking with a meter at battery terminals. Have checked with 3 voltage meters! Am only getting readings in the 12.49V to 12.73V range regardless of RPMs on my 4400 Ford Diesel. Getting less than 12V on the 3400 Diesel which has a brand new battery in it. So I'm assuming that
I'm simply reading the battery's voltage and that I'm not getting any output/charge from the generator. The generator will "motor" when jumped from positive battery terminal to armature lead on generator, with belt removed. Help! Previous post Tuesday/Wednesday lost? Thanks
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
3in Poly Pipe (A49461)
2011 New Holland B95B Cab MFWD Loader Backhoe (A51039)
2011 New Holland...
FUEL TANK/TOOL BOX COMBO (A50854)
FUEL TANK/TOOL BOX...
2007 Reitnouer 40 Ton T/A Flatbed Trailer (A49461)
2007 Reitnouer 40...
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
