Ford 335 all help is greatly appreciated
   / Ford 335 all help is greatly appreciated #1
jocww
SF Bay Area, Ca
JD 550c, 443 bobcat, had an old john ford FEL gone
Hey all,
i am going to purchase or am planning on purchasing a ford 335 from my neighbor on Wed. Just a few questions are these easy to work on? It is a "good worn out tractor, it leaks but fill her up and shell never die" the pins are loose but everything seems to work well enough. The hydraulics leak a little bit and the steering isnt the best but I have seen worse. How much are implements for this and where can I find parts for this tractor? He normally has someone come out and work on it for him but I would like to work on this myself.
TIA
Jon
   / Ford 335 all help is greatly appreciated #2
Most mid to larger category 1 three point hitch equipment will fit and work on a 335. These implements vary in brand, size, quality and price. Any New Holland dealer can supply OEM parts, and most of them also handle aftermarket parts from a variety of sources such as A&I, Tisco, Atlantic, Sparex, and others. You should buy service, parts, and an operator's manual. They can be purchased from New Holland here:
https://www.newhollandtechpubs.com/
Or pick up the phone and call them at 1-800-635-4913. Manuals often come up on eBay and other places as well. Be careful when looking at reprinted manuals, they often cost as much as an authorized original with lesser quality.
   / Ford 335 all help is greatly appreciated #3
Check us out for on-line parts. Dan
Partspring original New Holland parts
Thanks you guys I will do that.
Doesnt seem to be many owners on here. Is the 335 the bastard child of Ford or are they that old that people dont use them anymore:confused:
   / Ford 335 all help is greatly appreciated #5
The 335 is one of many "industrial derivatives" Ford built over the years. They start with a common general purpose configuration and swap in various combinations of components to create a specific purpose tractor. Front bolster, axle and grille shell, transmission, rear ring and pinion ratio, wheel equipment, etc. The beauty of it all is, within a specific HP range and frame size, these components generally are bolt-on swaps. There may not be many 335's around, but most of the components that make up a 335 are quite common.
Thanks Rick
So what would be todays version or model of it? What models should I look for when it comes to taking implements off of them? Sorry for all the questions.
   / Ford 335 all help is greatly appreciated #7
I might be looking at one of these as well.
Do they all come with cabs?
I am assuming the hydraulics for the loader should be better than a similar sized Ag tractor.
My guy is asking $6,000 for his. How much did you get yours for?
I am finding out more of the specifics now.
Yooper Dave
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
Valvoline 80//90 Gear Oil (A53117)
Valvoline 80//90...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2015 Chevrolet...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
