Ford 3000 very slow hydraulics
   / Ford 3000 very slow hydraulics #1
Mbbuk
Ford 3000
My Ford 3000 which I have owned for nine years appears to have a major hydraulic issue and unfortunately I'm not overly mechanically minded. I am in the UK and the tractor is 30-40 years old I would guess. I cannot lift the three point linkage at all in the winter and it will only lift in hot weather after the tractor has been running for several hours. I am desperate for some help and ideas!
   / Ford 3000 very slow hydraulics #2
I would start by changing the fluid and filter(s) of the hydraulic system
   / Ford 3000 very slow hydraulics #3
Sounds like you have a restriction in the hydraulic system.
The fluid has to get thinner via heat, in order to flow past it.
First thing I would do is check the pickup screen. :)
How do I do that? Is it a big job?
   / Ford 3000 very slow hydraulics #5
Install a hyd gage in the system and see where and if you have pressure. Activate all the valves when checking. If you don't have a manual, track down and draw out the flow path if possible. Your pump might be worn out. Is the fluid milky looking? Have you ever changed the fluid and filter?
To be honest, no. I have had the tractor nine years and the hydraulics have never worked properly. They used to be better than they are now. I used to have a rollermower that I needed to lift but have been using trail a long mowers for years now. I don't even know where to look to check the fluid level. I'm very sorry, I'm a complete novice! Thanks so much for any and all your help
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
JOHN DEERE CP690 LOT NUMBER 73 (A53084)
JOHN DEERE CP690...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
