My Ford 3000, 1966 model, gas, 3 cylinder was running rough. I put in new autolite plugs, new plug wires, new rotor, condenser and points. It is worse now, especially with open throttle. The bottom plate of the Holley Carb has been 'spitting' and it even spit out the gasket that was between the bottom plate and the carb. I reinstalled the gasket and it spit it out again. I attached a photo of the Holley Carb. On the photo, arrow #1 indicates the bottom plate (now without the gasket). Arrow #2 shows the broken gasket as it hangs below the carb.
Any suggestions on how to fix this problem? This was my first time doing a tune up but I think I got the gaps and everything right....but maybe not. The plug wires were difficult in making a secure connection on the plugs. Is the carb the most likely problem? I have a carb kit on the way. Thanks for any advice.
