Tire Selection Ford 3000 rear tires
   / Ford 3000 rear tires #1
cracker64
Hudson Fl
ford 3000
My '66 3000 has 11.2x28,will 14.9x28 clear? And will they rob too much power?
   / Ford 3000 rear tires #2
I have 14.9s on one of my 800s and they look a little big, but they are fine. I don't have a 3000, but if they work on an 800, I would guess that they would be ok on a 3000.
Two considerations:
1. They will speed up your ground speed a bit.
2. Fords have short lift arms. Bigger tires can cause clearnace issues with some 3pt impliments.
   / Ford 3000 rear tires #3
The difference might will also depend on your rims. They normally are two inches less then the tire size! 11 would need 8 or 9 inch wide rims. 14 should have about a 12 inch wide rim. What will happen is the tire will ride on the center if the rim is to narrow. Lower air pressure will help to correct that problem.
   / Ford 3000 rear tires #4
I had them on a '64 4000 with no problems. The ones I had had a smaller wheel diameter (and obviously wider wheel) than I have on my current wheels running 13.6s which are on a 11" width wheel as I recall....also runs 12.4s. Whole lot more rubber on the 14. Course you have a lot of options with all the wheel positions possible. More than enough room to run the wheels out for clearance. As I recall the manual lists all 3 tires I mentioned here as suitable for the tractor.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
Adams 8 Ton Weigh Hopper (A53472)
Adams 8 Ton Weigh...
