Hi everybody. I'm not posting often but I look at the forum when I need good advice from this great resource. I am not an experienced mechanic, but I already changed my pto seal, fixed some littles details on the lift cylinder (I am gonna have to come back on this one), and I am used to look at my service book and parts lists...
Right now I have a fairly small leak in the right brake, so few that you have to take the drum out to see that the hub is a bit wet. But just enough to loose braking power from that wheel. So I have a few questions for you guys.
First, I am assuming that changing the inner seal would fix it since the outer seal is to keep dirt from the bearing housing. I am right or do you think I have to get in the bigger job of changing the outer seal
If so, how hard is it to get the axle out. I know about the 9 or so bolts, but is there also a clip I have to reach inside the housing (I refer to the part number 39 on the parts figure)? And is the "differential-lock cluth parts" are going to fall if I pull the axle and do I have to engage it before pulling the axle out (like you have to do with the pto clutch)?
Will I see some difficulties to align everything when I get it back in?
So there are my questions. If it apears to be more difficult than I think, I'll probably just clean the brake once in a while. I already tried with gasoline without good results, next time I'll try to torch or boil the shoes...
So, thanks in advance for any answers or comments. Just hope I did my lessons by reading all the topics and that thoses questions were not covered before.
