My Ford 3000 is reading hot within 5 minutes of startup with the tractor out of gear at 1500 rpm. I checked the fluid temp and it was 180ーF. I got to looking at the voltage regulator and found that the voltage going to the battery was 14.8V which I thinks sounds reasonable. When I took the cover off the regulator the normally closed contact stayed closed, it had some magnetic pull, but not enough to open the coil. When I force the contact oper the normally open contact closed and the temperature reading went down. Can anyone explain exactly how the voltage regulator works. How would I check if the coil is bad? I'd like to be certain that the regulator is the problem before replacing.
