Ford 3000 power steering issues
   / Ford 3000 power steering issues #1
scjumper
Kingstree, SC
Ford 3000
I had a new power steering pump installed on my ford 3000 last week. The tractor steered good going straight with slight turns. Tried to make a complete turn around and it bent both the power steering cylinder shafts. I'm in the process of replacing both cylinders but can find no reason for the problem. Any suggestions. Thks
   / Ford 3000 power steering issues #2
The pump you bought is probably wrong for your application with a relief valve setting that is too high.
You need a 650 psi relief. Pressure is adjustable by removing shims to lower the setting.
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
Chevrolet Silverado Pickup Truck Bed (A49461)
Chevrolet...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
