Ford 3000 position control linkage
   / Ford 3000 position control linkage #1
ffejallen
southeast Louisiana
New Holland Boomer 41
The position control /draft control level hasn't worked since I bought this1969 Ford 3000 tractor. Finally got around to pulling the lift cover and there was no linkage between the lever and the inside parts. I don't understand why someone would remove linkage unless there was a problem. Do any of the ford guys know any reason to remove that linkage. I plan on changing both Hydro filters while the lift cover is off and add a ring to the piston. Is there anything else i should do while i have the cover off?
   / Ford 3000 position control linkage #2
check cam and service cam pin.. repalce all orings.. including the one on the piston / backup washer as well.
get the kit.. has the gasket and orings. rememebr the orings under the 3x5 option cover.
no rtv!
adjust using the alternate method inthe shop service manual for use without the nuday tools.
   / Ford 3000 position control linkage #3
Hi. I'm not sure about any linkage for the draft control. I believe the lever position controls the path of the fluid. One position floats the lift, meaning the implement is either all the way up or down and the other has a set height in relation to the position of the lever to the right of the seat. There are two hydraulic filters under the cover. For one you need to slide the PTO shaft out of the way to remove the filter. Lots of orings in there also. I bought a kit if I remember correctly. Hope that help. Matt
   / Ford 3000 position control linkage #4
the hyds are run by un unloading type valve.
no rtv!
Thanks for the info. I picked up the kit yesterday. I'll check the cam and service cam pin and order the linkage parts. Great tip on the bottle jack and 2x4 for removing the lift cover.
   / Ford 3000 position control linkage #6
saves yer back...
   / Ford 3000 position control linkage #7
I just did this last fall on my 3400 (same rear as 3000) and I almost feel like there wasn't any linkage specifically attached to the draft/flow control lever. If I remember right, when you move the lever up/down aren't you just adjusting the position of a cam that another component of the linkage (cam follower pin?) hits against? Maybe I'm remembering this all wrong, but it's worth going over the parts diagrams.
Tips:
One of the filters (left side as you sit on the machine) is metal mesh attached to a metal tube, and it is extremely expensive to replace. I didn't see any need to replace that and so I just made sure it was very clean before I put it back (it is literally 100% metal so there is nothing to wear out). I gather that most people do the same. You have to have the PTO shaft out to get this filter out in order to clean it properly, as it sits right against the base of the housing.
I had a leaky brake/clutch pedal seal. The way my loader was designed (standard 730 loader) I had to remove the loader (or split the tractor) to remove the clutch shaft to fix this. I decided to split the tractor which also made cleaning and getting the filter out easier. Removing the fender bolts was harder than splitting the tractor. So, if you have a leaky brake/clutch pedal shaft seal now is the time to fix that.
There were some o-rings that I needed that the kit didn't have, so I would recommend buying a good o-ring general purpose kit before you start this. People say that the unload valve o-ring is not included in the normal sets and that it is important to get that part specifically from NH, as it is an oddball o-ring. I can confirm from experience that this wasn't in my o-ring kit, and did not have an exact match in any of my o-ring sets so I was glad I ordered it separately.
To get one or two of the valves out you will want a slide hammer with an adapter for the appropriate thread (or weld your own onto something), I think you end up wanting 3/8" fine if I remember right. This is the part in the manual where it says you need "special ford tool x" and you really just need a slide hammer. If you don't have that, get a long bolt and a bunch of washers/spacers and you can make it work with that.
When you adjust the linkage read what they are saying in the service manual very, very carefully and you can understand how to do it correctly (which means no trial and error in re-assemblying everything) without their special tools. I literally read this part 5-10 times. Once you figure it out you'll realize all you need is a small depth gauge that you can make out of a small piece of metal/plastic and a file. If the measurement seems way off and you find yourself saying "I can't adjust the linkage that much" then you are measuring off the wrong spot like a lot of us have done, just read it more or ask here and you'll get it right.
I have only worked on this one machine for myself, so take everything I'm saying with a grain of salt. I could be remembering something wrong and describing it slightly incorrectly so if something I have told you doesn't line up with your situation, double check me on it.
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
New Holland 5 HP Hit And Miss Engine (RUNS) (A50774)
New Holland 5 HP...
Case IH Precision Disc 500T (A50120)
Case IH Precision...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
