Ford 3000 pin under the gearbox
   / Ford 3000 pin under the gearbox #1
MickeyB
Ford 3000
Can anyone please advise what the pin is under the gear box. I have had a few drops leaking from it - not sure if it is water or oil?
   / Ford 3000 pin under the gearbox #2
No idea what gear box or pin you are referring to, need to be a bit more clear on that but if it is the one under the clutch housing and looks like the end of a cotter key then it there to rattle around and keep the hole open so water, oil or whatever can drip out of the housing. A simple way to keep fluid from building up in the housing to damage the clutch.
If that is not what you are talking about post a pic.
   / Ford 3000 pin under the gearbox #3
If it is dark, black oil, then your engine rear main seal is leaking. If it is amber, clear oil, then you have a transmission input seal leaking.
2018 Schulte FX107 84in Rotary Cutter Attachment (A46683)
2018 Schulte FX107...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2016 Toro Reelmaster 3100D 72in Commercial Reel Mower (A46684)
2016 Toro...
2025 Kivel 48in...
Grain Truck Side (A49251)
Grain Truck Side...
TPM 18K Mini Excavator (A49251)
TPM 18K Mini...
