Patf10
- Joined
- Jun 17, 2009
- Messages
- 33
- Location
- Holbrook, Pa
- Tractor
- Ford 3000, Ford 4630 4wd, New Holland 1720, Kubota B7100HST
So i have a 72 ford 3000 that has been having an overheating issue for some time now. We purchased the tractor used of course, and shortly after the water pump went. We replaced that and noticed that the rad was all plugged up. So i took that to the shop and had it boiled out. Still overheats even after that. Found that someone had put a spacer in the vacuum advance and it wasnt working correctly, still wasnt the issue. So im at a loss, i dont think its running to lean. I have noticed when you turn the idle down the temp drops almost immediately i figure that has something to do with the voltage dropping from the generator at lower rpms? The only other thing would be, if the rad was all plugged up with corrosion could the inside of the block be the same? what works well for flushing a block?
