Ford 3000 Overheat
   / Ford 3000 Overheat #1
skytracker
Bronze Member
Hale, MI
Ford 3000
On a 1970 Ford 3000, 3 cyl. gas, with an FEL, trans 8F and 2R having overtemp problems. It sat for quite some time and needed a carb rebuild.
That done, it runs well now. Runs smooth and has good power. I will also check the timing and verify the under carb gasket to see if it is sucking in air. But either idling for some time or putting it to work will gradually overtemp, with the FEL and loaded rear tires it is heavy just moving around. Once when idling for a long period it shut down on it's own. Let it cool down starts right back up. Appears to have good coolant flow. I know it is missing the vacuum advance line from carb to intake and will replace that shortly. It looks like a very short metal line, could I use teflon or just metal??
I will check or replace the thermostat, and back flush the radiator fins. I have a solid state ignition kit for it I will do soon too.
Any other ideas or help is appreciated.
   / Ford 3000 Overheat #2
my little ford does that when not enough air gets to the radiator. dont think i am lucy enough for it to shut down by itself though rick
   / Ford 3000 Overheat #3
Vaccum advance line can be almost anything. Most cars use rubber. Check the air flow throught the radiator. You should be able to put a light on one side and see it from the other. Also check fan belt tension, loose belt can cause overheating. If it has an oil cooler you can get dirt between the cooler and the radiator that you cannot see easily.
Thank you for the replies. I have some rubber to make the line with to start. I will recheck the belt tension, I did before but I will make sure it is not slipping.
   / Ford 3000 Overheat #5
don't wast money on the e-ignition untill the advance is fixed.
make sure she's not lean too.. lean will cause heat..
Thanks Soundguy. What should I check to make sure it is not running lean?
I have good gas flow to the carb but I do need to re-check the under carb gasket.
   / Ford 3000 Overheat #7
if it has a holley carb.. lean is easy to come by. :)
hows she feel when you snatch the throttle open/
power seem fine?
manifold glow red at night? :)
   / Ford 3000 Overheat #8
Float level in carb, plugged jets, air leaks in intake manifold, mixtures screws improperly set. Spark plugs should be light brown. Gray or white plug color indicates too lean.
Seems to have good power and runs smooth. Holley Carb had a complete rebuild. Originally, bowl and everything was gummed up and green. I will have to re-check the mixture and plugs.
I did have the lower rad hose collapse, replaced with a new reinforced one. What generally causes that?
   / Ford 3000 Overheat #10
plugged core...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
