Ford 3000 oil dummy light
   / Ford 3000 oil dummy light #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
I want to do away with my oil dummy light on my ford 3000 diesel. I want to put a mechanical guage on it. How do Ido this do I just take off the low oil sending unit on the left side of the block and put the hose from the mecahnical guage right in or what? And also how many psi guage should I get
   / Ford 3000 oil dummy light #2
You can leave the idiot light on and intact and connect a mechanical gauge into the other 1/4" NPT hole on the block that is on the same horozontal plane. A light that comes on is more effective at getting your attention than a gauge needle that drops to zero. Nothing less than a 75 PSI gauge.
Where is this other other plug located on the block. And should it just run 30ish to 40ish like a normal truck motor
   / Ford 3000 oil dummy light #4
Additional plug is located directly aft of the current sending unit. oil pressure spec is 60-70psi @ 1000 ERPM.
Ok buddy yeah I looked and saw it thanks for your information
(1) UNUSED 5200# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 5200#...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
UNUSED FUTURE BC72 - 72" HYD BLOCK CRUSHER (A51248)
UNUSED FUTURE BC72...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
