Ford 3000 maintenance
   / Ford 3000 maintenance #1
peachhead
Hello all-
I recently had to replace the fuel tank on my '67 3000, which turned out to be a more major (fun though) undertaking than I thought. I ended up having to mount the tank on the opposite side from which it came. Anyway, I figured before I put it all back together I would do as much maintenance as possible. I've gotten a good bit done but am at a stopping point at the hydraulic filters. I have searched this forum and several others to get as much info as I can, as well as going through my service manual, and I'm curious to know if what I have put together in my head is correct. When I took the filler plug off (back right behind the seat, big plug with a G on it) I can see down in there, and it just doesn't seem like there's enough fluid in there. I pulled what I can gather to be the level plug and nice clean fluid started draining, so I put it back in and decided to come in and post this before I go any further.
Is that in fact the level plug, just above the right foot rest, and as far as I can tell, to change or clean my filters, I would have to take the lift cover off(which I don't think I want to do right now) - is that correct?
Does anyone know of a maintenance guide to this tractor? I have a service manual which is extremely helpful but sometimes it seems lacking in basic maintenance items, so I figure there is something else that I'm missing.
Just whack me if I'm asking too many stupid questions. I've spent countless hours searching this and other forums for answers to try to prevent calling for help, which has been very helpful so far. This is like having a massive encyclopedia online! :)
   / Ford 3000 maintenance #2
Not sure on the level plug without seeing a picture, but the filter changing if it is in the rear end housing is a major job.
Someone will be along to get you on the right track on the level plug.
   / Ford 3000 maintenance #3
yes.. yer filler plug is back on the center housing.. and the rear axle and hyds share oil... better part of 5g.. don't have my manual in front of me though... seems as if I remember buying 10g to do trans and rear sump.. had a lil left over..
soundguy
LMC LOT NUMBER 143 (A53084)
LMC LOT NUMBER 143...
1973 FORD 9000 TANDEM AXLE DUMP TRUCK (A52576)
1973 FORD 9000...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53472)
JOHN DEERE ROW...
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
BUSH HOG 7007 LOT NUMBER 111 (A53084)
BUSH HOG 7007 LOT...
