Ford 3000 lift stuck after first time use after sitting 3 years stuck in up position . Any ideas the problem. Thanks
   / Ford 3000 lift stuck after first time use after sitting 3 years stuck in up position . Any ideas the problem. Thanks #1
tsullins
Ford 3000
Lift stuck in up position on 3000 Ford , be sitting awhile after cranking lift raised now won’t go down
   / Ford 3000 lift stuck after first time use after sitting 3 years stuck in up position . Any ideas the problem. Thanks #2
Rust!
The cylinder needs to come apart. It's likely the transmission/rear end top plate that needs removed.
A ball hone is likely all it needs. Those cylinder packing tolerate abuse!
   / Ford 3000 lift stuck after first time use after sitting 3 years stuck in up position . Any ideas the problem. Thanks #3
Does the 3000 have a drop rate control? This is usually a knob located under the front of the seat.
Do you have any load on the arms?
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2002 Kountry Star Motorhome (A50324)
2002 Kountry Star...
2008 FREIGHTLINER B2 BUS CHASSIS (A52141)
2008 FREIGHTLINER...
2019 Ford F-250 XL (A50120)
2019 Ford F-250 XL...
Exmark Lazer Z (A50121)
Exmark Lazer Z...
