Ford 3000 ignition coil wiring
   / Ford 3000 ignition coil wiring #1
b8t
Hagerstown,MD
8N, Ford 3000 & Kubota B5200
I have a 1970 ford 3000 I am in need of a new ignition coil wiring harness (p/n C5NN14916B). My local dealer says it is no longer available. I am trying to find were I can get one or the wire specifications to make one.
   / Ford 3000 ignition coil wiring #2
they may or may not be available... rickb would know.. he's a hn parts man.
if you just need her to run, you got 2 options.
1, the oem setup was a 6v coil, and it had 2 wires run to it.. one was 12v during starting, and the other was a resistor wire from the run terminal on the key.. thus when running it had a resistive element in line with the 6v coil.
you could dupe that with an ignition resistor. OR get the correct resistor wire and keep the 6v coil.
or
just run a 14awg wire from the run and start position of the switch for the coil to a real 12v coil like a nap ic14sb that's a 16$ coil.
that coil and a few feet of wire and terminal ends will get you running.
your call
soundguy
   / Ford 3000 ignition coil wiring #3
It is a length of 14ga wire connected to a small stud on the start relay and the battery terminal on the ignition coil. make one up from commonly available electrical supplies.
thanks for the info.
b8t
Pallet of (11) 10 Lug Misc Wheels (A51573)
Pallet of (11) 10...
John Deere (A50322)
John Deere (A50322)
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
New/Unused CFG Industrial QK16R Mini Excavator (A51573)
New/Unused CFG...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
