Ford 3000 hydraulic adjustment lift cover
   / Ford 3000 hydraulic adjustment lift cover #1
appie3000
Holland
Ford 3000
Hello everybody, I am new to this forum and i,m from Holland.
I bought a Ford 3000 with my son to redecorate together. now I am looking for adjustment data to adjust the lifting device.
the previous owner got it loose and I don't have the correct information. data from a Ford dexta but I think that is not the right one. I hope someone can help us.
I will soon post more information about our tractor on the forum. greetings from the Netherlands, Robert
   / Ford 3000 hydraulic adjustment lift cover #2
Welcome to TBN Robert!!!
Not sure what adjustment is needed?? Please describe the problem you are having.
Hi Richard, thanks for your response. what i am looking for are the adjustment data of the hydraulic lift. there are bars under the lid and a turnbuckle must be adjusted for the draft control and position control of the hydraulic lift.
the adjustment that I have now used is from a dexta but that is apparently not the same as the adjustment of my Ford 3000 from late 60 "s
greeting robert
   / Ford 3000 hydraulic adjustment lift cover #4
I'm still not sure what the problem is or what you are looking for. I'll search for a Work Shop Manual for your 3000. It should give you the information you need.
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A53426)
2023 MAXEY G8X...
2020 BERGMANN C815S DUMP TRUCK (A51246)
2020 BERGMANN...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
