Ford 3000 Hydralic Problem
   / Ford 3000 Hydralic Problem #1
deejunk
Back in 1987 replaced a Draft Spacer or New Pin in Draft control, lost the worn part as a reference and am having a problem now with what started out as eratic lift problem, lower lift, sometimes lift briefly picks up and then goes down fast, very dangerous. When I push down Draft Lever, it is very hard to pull back into position control.
Now, thing will not function at all.
Anyone know where that part is described in the IT Manual FO-31 before I tear into this thing again?
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A51039)
Ditch Witch 6510A...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
71063 (A49346)
71063 (A49346)
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
