I've replaced the gas cap a few times over the years because they eventually won't stay tight, begin to jiggle allowing fuel to splash out on bumps etc... The only replacement ones I've found are round Crome ones on eBay/Amazon and when put on tighten, but EASILY jar loose or continue to turn with some friction but will come loose soon after using. The tank fill neck has a pin hole in it, so seems the cap would be ventless, but they look like they have a piece on the underside of the cap vs solid cap.
I've ended up only being able to fill the tank 1/2 , gently tighten the cap and duck tape the dang thing so it won't jiggle loose. Even then it eventually jiggles around but at least doesn't come off.
Was wondering if there was some kind of adjustment that could done to the cap or lip on the tank etc...
Thanks.....
Thanks.....
