dford
I have just purchased a 1971 Ford 3000 3cy gas tractor. The right brake is stiff and will not return pedal. Pulled brake drum, ok, found problem in shaft going to rear differental housing. Does this shaft have a bushing that can be changed from outside or is shaft locked into housing?
Also clutch pedal shaft going into case is leaking a lot. Can that be repaired from outside or does tractor have to be split?
Thanks for your help.
