Front-End Loader Ford 3000 Front End Loader Pump Shaft Not Aligned With Access Hole in Axle
   / Ford 3000 Front End Loader Pump Shaft Not Aligned With Access Hole in Axle #1
KyleD
Glennville, GA
Ford 3000
While installing a Ford front end loader on a '66 3000, the shaft that drives the pump does not line up with the hole in the axle. I bolted the hub with the spline to the crankshaft pulley, and the pump shaft does not line up correctly. I loosened the bolts and was able to install the shaft, but when I tightened it back up, it rubs where it passes through the axle. When I say it rubs, I mean that it started to smoke when I started the engine. I know it cannot operate like this, but I don't see any adjustment to align the crankshaft pulley with the access hole in the front.
Has anyone ever encountered this before? What can I do to correct the alignment?
Thanks in advance for any help on this matter.
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
John Deere 960 Culitivator (A50514)
John Deere 960...
2016 FORD F-150 (A50854)
2016 FORD F-150...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
