Ford 3000 diesel
   / Ford 3000 diesel #1
h10doc
Bronze Member
Collierville,TN
Tc45D
3000 diesel will not run under a load runs good at most rpms high rpm smokes and misses. This started after it ran out of fuel
   / Ford 3000 diesel #2
have you changed the fuel filter?
good flow to the pump?
bleed to the pump?
bleed injectors?
made sure no leaks to suck air and no seeping at injectors?
baring real mechanical problems ...most diesels that simply fail to make rpm or make rpm under load are fuel starved.
have you serviced the air filter? checked for birds nests?
serviced the inline pump cam box.. oil or diesel in it?
any time i run one out of go juice I change the filter(s) and check flow from tank and at each location before the pump
post back
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
