Ford 3000 diesel knock
   / Ford 3000 diesel knock #1
Catoosa
Bronze Member
Catoosa, OK
Ford 3000 & 3600
Bought a Ford 3000 diesel in 05 with a loader and have been working it during the summer months every since, mostly mowing 8 acres and moving gravel for the drive. It has always had a knock that if I didn't think different would swear was a rod. Don't believe a rod knock would last 12 years and who knows how many hours. Couple years ago I had the injectors rebuilt thinking one may be causing the knock This fall I checked the valve adjustments, again just trying to eliminate the obvious.
Never owned a diesel anything before and wondering if I should even be concerned at all.
   / Ford 3000 diesel knock #2
The 3000 knocks.. period.
You could try adjusting the pump timing..IF its a CAV pump..
look on the mounting flange of the pump and you'll see a scribe line.. that line lines up w/ * marks on the engine block.
They may be painted over but they're there. Loosen the pump & rotate it to the "0" * mark on the engine.
Merry Christmas..
Thanks for the pump tip, will check it next time I get the tractor out.
Sounds like it isn't anything to be too worried about.
   / Ford 3000 diesel knock #4
Have you starved each cyl to see if that kills the knock? ( remember to be safe, diesel injected under the skin is extremely dangerous, so no skin near pressurized fluids.. Tools only!)
Haven't done anything for a while too durn cold to be messing with it outside. I did see a YouTube video where a guy was plowing with a 3000 and it had exactly the same knock mine has. I know that doesn't mean it's right but gives me one more reason to believe it's pretty normal for that engine.
   / Ford 3000 diesel knock #6
Yanmars hammer... a good 3000 shouldn't knock..
2002 CATERPILLAR 973C CRAWLER LOADER (A51246)
2002 CATERPILLAR...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2019 CATERPILLAR 330GC LONG REACH EXCAVATOR (A51246)
2019 CATERPILLAR...
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
2012 Honda Accord LX Sedan (A51694)
2012 Honda Accord...
