Hi,
I decided after reading everything I could find on clutch adjustment twice, I would post to see if anybody could help me with a small problem.
The tractor is a Ford 3000, from October 2, 1968. It has 6800 hours, and most likely has been worked on before as there are sleeves in the block. I just had the clutch rebuilt and got it put back onto the flywheel, and the tractor put back together. Now the problem is that when I push down on the clutch, it falls down to about an inch off the platform. The clutch rod from the pedal to the lever is 27.5" and is adjusted as short as possible, but still doesn't have much of a push until it hits the platform. The lever connected to the rod running through the bell housing is straight down when it goes click, touching the fingers on the clutch assembly. This lever looks like it has been broken off before and welded back on, so it's possible that it's not in the correct position. I tried my own "made-up" rod just to see if the clutch actually worked, and it does just the pedal doesn't have enough bite to get it to work.
How can I adjust the clutch so that it will work? I still have it torn apart waiting for parts for the engine, so it's easy to pull it back apart to adjust the clutch assembly itself. The only thing I can think of is to cut the clutch rod off about an inch and re-thread it so that it will be short enough.
If anybody can help it will be greatly appreciated! I've had this thing split 5 times now just to make sure it's right. I can supply as many pictures as you need, just let me know.
-Jon
-Jon
