tiltbed
Bronze Member
- Joined
- Sep 27, 2002
- Messages
- 83
- Location
- Ohio
- Tractor
- ford 3000,case SI..Just purchased a 404 Futon (40 hp 4wd) with a koyker FEL
Boy this one has me buffaloed....Haven`t used the 3000 much since i bought the 404 4wd.Any how neighbor needed some holes agured for a fence.of corse i was elected seeing that my ph digger was on the 3000.Every thing was going good...the last hole i did the 3pt would not lift ? thought it was caught on a root so tried to rock it....nope.Then i noticed that my lift handle had pressure on it when i tried to lift the 3pt. Shut the tractor off while we tried to figure it out.Neighbor thought if i could try the 3 pt he would use a pipe wrench on the ph digger and back it out.Started the 3000 up and the 3 pt worked fine????Now i`m really buffaloed.Ok I have had an on going problem with this for many years....when the 3 pt is up the FEL works very slow and jerky....also the pressure and return hoses for the FEL constantaly pulsate. /forums/images/graemlins/confused.gif If the 3 pt is in the down position the FEL works somewhat normal.Right now the 3pt is in the down position and won`t raise also noticed pressure on the 3 pt handle as before...I do all of my mechanical work...but this one has me almost saying Passsssssss...thanks for any and all words of encouragement....By any chance could the pressure and return hoses be reversed on the FEL control valve?..this seemed to be new when i purchased the tractor?..thanks again, Sid
