Ford 3 point very weak after changing fluid
   / Ford 3 point very weak after changing fluid #1
kmacht
Colchester CT
63 Ford 4000
I have been having some issues with my 63 Ford 4000 3 point lift. I bought the tractor a year ago and the lift had plenty of power but I only used it to lift a logging winch. It was either always full up or full down. I tried hooking a post hold auger up the other day and when I tried to raise or lower it the lift was very jerky. I bought a top cover gasket/o-ring kit thinking that maybe it was time for a rebuild. When I went to drain the fluid last night what came out obviously had a lot of water in it. It was a very light chocolate milk color. Thinking maybe this was the issue I drained and re-filled with new fluid. Having the gasket kit I decided to pull the small block off plate right in front of the seat and re-place the O-rings since it as easily accessible. Once I got that cover off I noticed there was a spring loaded valve of some sort. I unscrewed the cap holding the valve in place and two springs that fit inside each other came out. Nothing else came out and I didn't try to actually pull the valve. I put that back together and bolted the block off plate back on with the new O-rings.
I then started the tractor and the 3 point didn't work at all. I figured that the pump lost prime so I loosened the allen screw on the pump until only fluid was coming out. That got the lift moving but it has absolutely no lifting power. If I try to raise it up I can hold it down by just pushing on it by hand. Once it does raise up I can push it back down even without moving the control lever. When I shut the tractor off the lift immediately drops back down to the ground. It is almost like the fluid is bypassing a check valve or something. I plan ot order a service manual tonight but could really use to get this working again for the holiday weekend. Any idea what to check? I should note that I don't see anything squirting out of the cylinder by looking through the fill cap and the draft control lever is up for position mode.
Keith
   / Ford 3 point very weak after changing fluid #2
Heya Keith, welcome here. Someone should be along to help, sorry it ain't me I don't know enough about 'em. I know sometimes on my 641 I have to drop the lever all the way down for a minute before the 3pt will rise as I raise the lever back up. Post back what you end up finding!
   / Ford 3 point very weak after changing fluid #3
Was it the lift check valve that you tinkered with , in front of that 3x5 cover? or under the cover?
Quick Attach Pallet Forks (A47384)
Quick Attach...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
Roose Hog Cart (A50515)
Roose Hog Cart...
