Before going to the expense of a carb. rebuild kit, try this. (Click on the link below to show the exploded view of your carb.)
Shut the fuel off at the carb. Remove the fuel line at the carb., then open the fuel valve, and make sure you have good flow to there. If you are good to there, remove the brass elbow fitting ( #16 in the exploded view) where the fuel line attaches to the carb. This should have a fine mesh screen on it when you get it out. A can of spray carb. cleaner will clean this up, spraying from the outside, and flush back through, to the open end. Hold it up to the light, and make sure the screen is clean. If you have a compressor, a spritz of air back through the screen for a final cleanup. Re-install the elbow, connect the fuel line, turn on the gas, and try it then. If it still needs the choke to run, you need to go a little deeper.
You'll need to remove the carb. from the manifold. Remove the bowl, being careful not to damage the gasket, and be very careful not to bump the float, and knock it out of adjustment There will more than likely be some sediment, and crud in the bottom. If the gasket was not damaged, or distorted when you take it apart, it should seal back up OK. More carb. cleaner to flush that out. Remove the jets ( Items #20 & #22), and spray through those ports. Hold it away from your face, or wear safety goggles,as it can spray back in your face. Remove the discharge nozzle ( #9). A 1/4" drive deep well socket to fit the hex fitting ( maybe 7/16"..??), or a hollow nut driver may be needed to take that out. Be careful not to lose the tiny fiber washer that may come out with it. Look towards the bottom of that nozzle for two tiny cross drilled holes in that tube. Hold it up to the light, and make sure they are open. If not, pluck a wire from a wire brush, or use a strand of wire from a piece of automotive type braided copper wire as a cleaner. Spray with carb. cleaner to make sure it they are open.
Spray carb. cleaner through all of the open ports you can see. Reassemble, and try it then. The main jet should be set at 1-1/2 turns out from the bottom, and the idle jet at 3/4 turn out from the bottom. Just run them in easy until you feel them seat, then turn back out. This will be close enough to get it running. You can tweek/fine tune them when you get it running.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
