Ford 2600 turning problem
   / Ford 2600 turning problem #1
jimbobs61
Boston, Alabama
Kubota 3200 with FEL
My Ford 2600 has a problem turning in either direction. The front wheels skid in any kind of tight turn. Anybody got ideas on what the problem is?
Thanks, Jim
   / Ford 2600 turning problem #2
Make sure the differential lock isnt stuck engaged.
Bill
   / Ford 2600 turning problem #3
Lack of weight on the front.
   / Ford 2600 turning problem #4
G'day i agree with hooked the diff lock sounds like the place to start I have had to pull quite a few to bits because the diff lock has jammed on after using it , they unfortunately seize on due to a lack of use sometimes you can be lucky and jack one wheel up and rock it whilst someone operates the control and apply heaps of penetrene to any pivots best of luck:)
You guys were dead on. The differential lock was stuck. Got it unstuck by going foward and reverse a little and pulling up on the lever. Turns great now! Thanks all. Jim
1265 (A50490)
1265 (A50490)
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
PALLET OF HYDRAULIC HOSES (A50854)
PALLET OF...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
