Ford 2600 Filter Options
   / Ford 2600 Filter Options #2
It looks as though the 2600 can use either a single or dual filter. I have included a link to the page on the New Holland website. You might confirm the model and year or you could use their site for your own search. Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
I don't have an answer if the filter you are looking at will work on your tractor but you could compare the OEM numbers on the New Holland website and they might be the same. Good luck.
   / Ford 2600 Filter Options #3
The dual filter setup was an option on the 2600. You of course need to modify the lines.
Also, you can add a glass bowl to the single filter setup to check on water/sediment.
Thanks all for the help. I went ahead and bought the two filter setup (probably overkill). I have flex lines already to the tank and injector pump but would like to make up new shorter lines. Just need to get the plastic return line to the filter for the two filter setup. BTW, where is the best place to get 1/2"-20 to barb fitting so I can make custom length lines?
JC
   / Ford 2600 Filter Options #5
Hardware store or Ebay?
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
