Ford 2600, FEL weak
   / Ford 2600, FEL weak #1
ACR
Hi All, I have a Ford 2600 with a FEL and it just doesn't seem to have that much strength. Not even enough to lift the front tires off the ground. The fluid level is good and the hydo filter has been replaced. The FEL will very slowly drop (same with the 3pt) so there seems to be some bypass somewhere.
I've only had it for about 6 months now. So I have no idea when the last time the hydro fluid was replaced. I could replace the fluid but I don't suspect that will correct the problem.
Any ideas on where I should start with troubleshooting? I would like to try to fix it myself. My guess would be the hydro pump but just figured I'd ask. Any info would be appriciated!
   / Ford 2600, FEL weak #2
SIR,
i suggest you check the simple things first.
do you have a pressure gage? if so, check
the pressure. if it is not up to what it should be,
it could be the relief valve, this can be adjusted.
if you cannot adjust it, then look for something
more serious. if you have to buy a gage, try to get
one that is oil filled, and has enough pressure above
what you are going to check for.
good luck.
accordionman
wlbrown
   / Ford 2600, FEL weak #3
You don't give us much to go on... What's the loader pressure supplied by.. the tractor onboard engine mounted pump? a stinger pump? and aux belt driven pump.. etc.
If the laoder is off a stinger pump.. then the fact that the 3pt also drops will be unrelated as they are on different systems ( 3pt dropping can be relief or bad lift piston ring. )
I agree with the other advice... pressure test the system... 3000 psi gauges are good for most tractor applications as you usually don't see over 2500 psi in these applications..
Soundguy
   / Ford 2600, FEL weak #4
You changed the filter. Did you clean or replace the suction screen???
ron
Thanks for the replies. The loader runs off the aux. hydro svcs. There's a valve under the seat to switch control from the 3 pt to the svcs.
I don't have a pressure gauge. I have a friend that works for bobcat, I'll see if I can borrow one.
I'll check the relief valve, I totally forgot about that! I don't recall seeing anything about a suction screen in the manual. It did mention two filters but that seemed to be for the larger models. I'll take another look for it.
International 1086 Cab Tractor 2wd (A52128)
International 1086...
66" Skidloader Tooth Bucket (A50774)
66" Skidloader...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
2008 International 4400 (A50323)
2008 International...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
