Ford 2120 pto sprag clutch change
   / Ford 2120 pto sprag clutch change #1
shpa72
I have a 1994 2120 with EHSS 12x12 transmission that uses the one way bearing (sprag clutch) to drive the PTO. I am pretty sure my pto is loosing power and stopping due to this. I bought the Ford/New Holland major shop manual not the I-T manual and it appears I have to split the tractor between the transmission and rear end to change this but from reading posts I get the feeling this can be changed by going thru the top cover. Has anyone actually changed this and can you give me any advice. I am fairly mechanical and have worked on heavy equipment and aircraft for many years but that is always at work. Kinda want to know what I'm getting into when it's on my buck.
Thank you.
By the looks of all the diagrams it appears I should be able to remove the top pto cover off the rear end and slide the countershaft back enough to R&R the sprag clutch, is that correct.
Thank you in advance.
Cultipacker (A49251)
2011 Land Rover Range Rover Sport AWD SUV (A48082)
2011 Land Rover...
Steel Tank (A49251)
Steel Tank (A49251)
2022 Club Car...
Hot Water Boiler (A49251)
Hot Water Boiler...
12,000 LB Axle (pair) (A49251)
12,000 LB Axle...
