Gwydyr
Hi, this is my first post here so I apologize if my inexperience shows. I have my Dad's 1992 Ford 2120 which I've taken pride in always starting. However since an abortive start attempt on a 0 degree morning which very quickly killed the battery (I know I should have had it plugged in but it was outside that night) it has started only once. After swapping the battery, the lights would come on but when I turned the key to start or to turn on the glow plugs the light would go out and there would be silence. I jumped from the battery to the solenoid and nothing. I cleaned all the electrical connections and it started so I could bring it back inside. Since then it hasn't started and has had the same symptoms. I replaced the starter relay switch and the solenoid to no avail. I've cleaned the electrical connections and fiddled with the all the wires but no luck. If I jump the solenoid I get a click in the starter relay but that's it. I'm already over my head in diesel engines and electronics, what should I test next?
Thanks for your help-Steve
