3-Point Hitch Ford 2000
   / Ford 2000 #1
Mtcrash77
Ford 2000
My 1975 ford 2000 raises the bush hog up to max height as soon as the engine is started. This crunches the drive shaft into the mower housing and will melt metal if the shaft is turning. If I engage and disengage the lever for draft control 3-4 times the 3 point hitch will operate properly again. When the tractor cools down the problem recurs. What is clogging up in the hydraulic system which makes this happen and how can it be remedied?
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2019 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2019 Ford F-550 XL...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
DOUBLE WALLED FUEL TANK/TOOL ROOM SKID (A50854)
DOUBLE WALLED FUEL...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
