Ford 2000 won't turn over
   / Ford 2000 won't turn over #1
Bobby R
1972 Ford 2000
I went out to use my tractor this morning and it wouldn't turn over. It cranked and ran fine a couple of days ago when I used it. I checked the battery and it appeared to be okay, but I put my charger on it anyway. I've tried starting it at the solenoid, checked cable connections at all points, and everything else I know to check and try. It won't even click when I try to start it. Any ideas? It's a 3 clinder gasoline, about a 1972 model.
   / Ford 2000 won't turn over #2
Are you saying you tried jumping over the solenoid? If not, give that a shot. If that doesn’t work, a multi-meter should find the problem area pretty fast. If you can’t get it to crank by jumping from the battery to the starter, one of those two is the culprit.
   / Ford 2000 won't turn over #3
Sounds like a dead battery. Or a faulty ignition switch. Got mice? They chew the snickers out of wires. Hate the little buggers...
Thanks for your suggestions guys. I just got through messing with it again, and found the problem. I had to put the hi/low range shifter in neutral position. Then it started. I've not had to do that in the past, so I'm guessing there's a safety switch in there or something that must have been stuck before, and is working now. Anyway, I've got it going again, and thanks again for your help!
   / Ford 2000 won't turn over #5
yes there is a neutral safety switch inside the trans on the high and low lever
Okay, I thought there must be. Thanks!
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Year: 2015 Make: Peterbilt Model: 320 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2015 Make...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
E-Z TRENCH GROUND SAW (A51244)
E-Z TRENCH GROUND...
John Deere 348 Square Baler (NICE) (A50774)
John Deere 348...
