Ford 2000 tractor cav injector pump
   / Ford 2000 tractor cav injector pump #1
bigearl42
Beulah Alabama
2003 FarmPro 2420
got my pump back from the rebuild shop but when I connect the injector line they leak. I put new metal washers. Is there any thing else I can try to stop the leaking like tape or something?
   / Ford 2000 tractor cav injector pump #2
There are no metal washers used on the high pressure injector tubes. Also no tape, dope, or other sealant. The only washers used on the high pressure connections atr at the banjo adapters right on the pump head. And every pump shop I have ever dealt with installs those adapters so the installer doesn't have to fuss with them.
Quick Kurb Continuous Curbing System with MEGA MARKER (A49461)
Quick Kurb...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
2013 HINO 388 (A50854)
2019 PJ 25 T/A GOOSENECK TRAILER (A50854)
2019 PJ 25 T/A...
