Ford 2000 Hydraulic Leak
   / Ford 2000 Hydraulic Leak #1
Mearntain
Gates, NC
Ford 2000
EDIT: HOW CAN I DELETE THIS?? I FOUND THE FORD SECTION TO POST THIS IN AND DIDNT WAMT TO HAVE THIS DOUBLE POSTED. IM NOT SEEING A DELETE BUTTON ANYWHERE. MAYBE A MOD CAN HELP ME??
First off, I'd like to apologize if this is in the wrong spot as this is my first post here. I thought I'd been frequenting a ford section on here in the past but I can't seem to find it now.
As the title says, I've got a 3 cyl Ford 2000, I believe it's a '68 but the specific year shouldn't matter. On the right side of the tractor, there are 2 lines (1 larger 1 smaller diameter) running there in which I assume both are hyd lines. There's a bit of hyd oil over the fitting where it enters the rear (underneath the foot rest by the brake pedals) so I know that's leaking but am unsure of the small line.
While I'm at it, I would prefer to go ahead and replace both of the lines seals. I have a repair manual for the tractor, but can't find any info on the names of the parts/seals I need nor can I find a diagram of the parts either. No luck online yet either.
Can someone direct me towards the parts I need for the repair and if someone had a diagram to share, that would be awesome. Part numbers and any tips/things to watch out for when I'm doing this would be a plus! Thanks!
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
