ford 2000 fuel lines
   / ford 2000 fuel lines #1
kennyl123
Bronze Member
Pollock, LA
Ford 2000
I have a ford 2000 3 cyl diesel 1972 and it caught on fire ( electrical short) It melted all the fuel hoses from the fuel filter. I have searched ford parts list and all the lines says not serviced
the only rigid lines are the intake from tank and the three injector lines. I bought 1/4 fuel hose and barb connector but the barb connector threads are not the same as the ones removed from
filter. The inj. pump has barb conn. on bleed off and return lines. How can I solve this? The return line has a ferrel type at filter and hose barb at pump. Thanks for info.
   / ford 2000 fuel lines #2
All the rubber lines are low pressure. Regular fuel line you buy at the auto parts store works with SS clamps on hose barbs which are there for purchasing too. If you burned off the injector overflow return lines, Ford makes a drop in replacement that has the 3 input rings all joined to a tail line that goes back to the fuel tank. I bought one for my 3000; surely there is one for the 2000 3 cyl. I may still have the part number in my file cabinet.
What else do you need?
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
TAKEUCHI TS60R SKID STEER (A51246)
TAKEUCHI TS60R...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
