Hello! This is my first post and I love this site! I have a Ford 2000 model# B1023B and Serial # C479709. I think its a 1975 model. It has a Zenith Carb. and the Tab numbers are 02 07 and 13915B and E1NNDA. I have been searching for a carb. Kit. Every kit I have looked at, the main gasket that splits the carb into, is not the same as the gasket on the carb now. The closest kit I can find is one for a Zenith 13915 not a B. Would this kit work for me?? The Carb is leaking gas out the weep hole. The needle and seat look new. I have cleaned the entire carb and all the jets, but it is still leaking. The float does not leak and is good. I have tested the float and needle and It seems to be working good. My though is the gasket is not sealing off the gas correctly and gas is spilling over into the intake and out the weep hole. Thank you for all your help!
