Just joined up here, and been doing a lot of searching and reading. Have learned a lot, but still looking for answers on some carb issues on my 1963 Ford 2000, 4 cyl gas. Sorry for the long read...
Have all the electrical issues taken care off: new plugs, wires, ign coil, points/condensor, dist cap. Had the gas tank removed, boiled/cleaned/sealed. Only non ethanol gas in it since then. Did all of this, just after I bought the tractor, and it ran great for several weeks. Started running rough, and started messing with the carb. It is a MS carb. I thought I had it narrowed down to the float valve needle sticking, and not letting fuel into the carb.
Put a (small?) rebuild kit in it. New float valve needle and seat, and new float as well. After putting the carb back on, the tractor started right up, and ran better than it has in the few months that I have had it. Got the carb adjustments down perfect, it would idle and run just fine. I could shut it off, and it would start right back up.
Went back out the next day, and could get it to start, but could not keep it running for nothing. Banging on the top of the carb would help for it run for 10 to 20 seconds, and then not run again. I have removed the carb multiple times, monkeying with the seat, it appeared to be sticking in the up position. Talked with a buddy at work, who called his dad up who worked on these things years ago. He claims the needle sticking is an issue with these. He said to remove some material from the 3 edges of the needle.
I took the needle from .201" down to about .185". Put it back in the seat, and it had plenty of room and did not seem to "bind" up in it. Put the carb back on the tractor, and still won't run right. Took the carb back off, and sanded a tiny bit of the plastic tip of the needle off. Put the carb back on, and all kinds of fuel flow now. Pouring out of the carb now.
Any helpful ideas from anyone? Going to try another new needle, and if that doesn't fix it, and may just replace the carb with an new one. I have found an aftermarket one for $200.
Thanks in advance.
Thanks in advance.
