ford 2000 3 cylinder gauge cluster
   / ford 2000 3 cylinder gauge cluster #1
richardy01
Grafton, OH
Ford 2000 3 cylinder
What do you use for nuts when installing new gauge cluster and gasket?
   / ford 2000 3 cylinder gauge cluster #2
You gotta give us more details?? The cluster on my 3910 is held in place by 4 screws. They screw into holes in the metal enclosure and have not "nuts".
Is yours not like that??
Welcome to TBN!!! :)
There are little speed nuts that clip onto the cowl opening and accept the screws.
The original gasket had nuts that were molded into the rubber gasket. The after market gasket does not have these nuts. I bought the clips today. Got the right size for the screws, but not sure if the right size to clip on the sheet metal. Thanks guys for your help.
Stump Grab Bucket (A50322)
Stump Grab Bucket...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
