Ford 2000 3 cyl. Diesel fuel problem
   / Ford 2000 3 cyl. Diesel fuel problem #1
tigersbait
Bush, La
Kubota B2100 HST
I have a Ford 2000 2WD 3 cylinder diesel tractor and am not getting fuel to the injectors. I had pulled the steering box off of it to rebuild and it wound up sitting approximately a year before I got it back together again due to having another tractor to use. The tractor ran and started fine prior to this but now I cannot seem to get fuel up to the injectors. I am assuming the pump bled down from sitting and has air in it. Fuel is getting to the pump as far as I can see. I broke lines loose coming from the filter to the pump and there is fuel present. I connected jumper cables to my truck and the tractor to spin it over hoping to get it primed but still nothing. Is there something else that may be wrong?
   / Ford 2000 3 cyl. Diesel fuel problem #2
Make sure you have good flow from the tank through the filter and then to the pump.
   / Ford 2000 3 cyl. Diesel fuel problem #3
I have a 2600 so may not be the same but I'm thinking there's a bleeder valve on the pump versus opening the lines.
Also, I had to leave injector lines cracked open until tractor cranked before I could close. I made the mistake of checking for fuel and closing back first.
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A51573)
Vermeer D16X20A...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
LOT LOCATIONS (A52576)
