ford 1920 advice
   / ford 1920 advice #1
catexc
central ma
Kubota B21, CAT 416B Backhoe, Simplicity Landlord Dlx Tractor
Hello all. I'm new to the group and am looking for some advise on what to do with my 1920. It has the factory loader and 758b sub frame backhoe with 1682 hours on it. I bought it about 3 years ago and have found multiple issues since.
First off, I might a frozen PTO disc. It has the 12x12 non hydraulic shuttle, and the PTO shaft keeps spinning with the clutch depressed. The transmission doesn't slip and seems to operates normally.
Second is where the backhoe's subframe and where the lower arms of the 3 point hitch mount to rear axle housing. The 2 bolts holding the main pin to the rear axle wheel shaft case sheared off and in the process broke out the bottom of the housing because the back of the pin is doweled into the housing about a quarter of an inch. Now all that holds the pin that hangs the backhoe's subframe and backhoe itself or the lower 3 point hitch arm on that side of the machine are 2 m12x30 bolts. It had happened the previous owner, but I didn't see it until it happened to me.
The third problem is with the boom and dipper cylinders on the backhoe. When the cylinders were fully extended, the rods bent on me. There was compression pressure on the cylinders, and rather then the rods just retract into their barrels slightly, they just popped and bent. I would have figured some relief would have kicked in and allowed the cylinders to bypass before the rods bent like that.
My question to you all is this...should I walk away from this machine or stick with it and repair it for the long haul? From what I gather the 1920 was one of ford's best tractors. I think my machine was used hard, but not necessarily abused. I thought it was in average shape when I bought it, but now I'm woundering.
I missed out on buying 2 different used kubota b20 TLB's. I like the solid industrial strength build of these units. What is everybodies opinion of a trade of the 1920 for a b20 or b21? I've also talked to a mahindra dealer on trade in possibilities. What does everybody think of mahindra? I'm very unfamiliar with them. Just seems like I'm at a fork in the road with this 1920. Thanks for any and all advise!
   / ford 1920 advice #2
Your tractor has a dual clutch. One disk powers the transmission and the other disk powers the pto. Aparently your pto disk is stuck or your free play on your pedal is not adjusted properly. The way it works is if you press the clutch pedal half way down it stops the motion of the tractor. When you depress the pedal all the way it stops the pto.
The lower pins for the lift arms can be welded. The ones on my 1900 were broke and I welded them with stainless rod. They have held up for 5 yrs.
There should be a releif valve on the hydraulic system. Aparently yours isn't working or someone cranked the pressure way up. This needs to be repaired befor you wreck the pump or damage more cylinders.
Bill
   / ford 1920 advice #3
Does the pto spin when it shouldn't if there is an implement, or is it just open?
   / ford 1920 advice #4
I would never trade my 1920 w/fel and BH for a kubtoa B series (maybe an L series :) ).
I'd say fix it and it'll last a long time. The 1920 and its bigger brother, the 2120 was some of Ford's best compact tractors. Parts are readily available as well as documentation. Not to mention the wealth of knowledge from the guys here. I split my tractor and replaced my clutch using the service manual and help from here.
It wasn't that bad and man, the new clutch just feels great.:thumbsup:
thread here:
http://www.tractorbynet.com/forums/...g/212901-ford-nh-1920-clutch-replacement.html
Read Mike's thread first:
http://www.tractorbynet.com/forums/...ting/120911-ford-1920-clutch-help-needed.html
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
(APPROX 80) 2" X 3" X 19 3/8" ANGLE IRON (A51247)
(APPROX 80) 2" X...
2" X 3" ANGLE IRON UP TO 16' LONG (A51247)
2" X 3" ANGLE IRON...
2013 Volkswagen Passat Sedan (A51694)
2013 Volkswagen...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
