Ford 1920 90yr measurement of wooden clutch pedal spacer
   / Ford 1920 90yr measurement of wooden clutch pedal spacer #1
Atvjoe
Bronze Member
Miami, Florida
Ford New Holland 1920 Yr 1990 With loader SMC 84Q
Hi to all, does anyone have the Wood Block clutch spacer measurements, so I can make one. I have searched with no luck. My tractor sits for a good while and I don稚 want the clutch to stick in this Florida weather. Thank you all for your help..
   / Ford 1920 90yr measurement of wooden clutch pedal spacer #2
I don't use a block but one of the cheap bar clamps from Harbor Freight. They are not good for a lot more. This is the best and highest use.
   / Ford 1920 90yr measurement of wooden clutch pedal spacer #3
there is plenty of good info here to explain the mechanism, once that's understood then one realizes even small short piece of 2x4 just work as the OEM plastic jobby.
   / Ford 1920 90yr measurement of wooden clutch pedal spacer #4
Find the spot where the block goes. Push the clutch pedal until the clutch is released. Take a measurement.
Thanks for the info
Thanks to everyone
Mccormick X6.55 (A50123)
Mccormick X6.55...
VARIETY BOX OF SCHUMACHER BATTERY CHARGERS (A51248)
VARIETY BOX OF...
UNUSED MOWER KING SSAB72-72" HYD ANGLE BROOM (A51248)
UNUSED MOWER KING...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
