Ford 1920 3 point lift oscillating
   / Ford 1920 3 point lift oscillating #1
double hunter
Ford 1715
New to me Ford 1920 lift problems, when the lift is at any position it oscilates, it will go up to that point and drop back, go back up and drop back, about a quarter of the the way, doesn't matter if all the way up or half way up, check the fluid and changed the filter, no help, are the pumps hard to workon, any help appreciated.
   / Ford 1920 3 point lift oscillating #2
sounds like leakdown and circuit regen. does speed change at different rpms and loads?
The higher the rpm the faster the oscillations, the lift comes up slower than i think it should with no load.
   / Ford 1920 3 point lift oscillating #4
I have this problem on a Massey 40 I'm restoring, I have read that this is usually caused by worn or broken piston rings on the hydraulic pump. Not sure how similar the Massey pumps are to Ford, but I've seen rebuild kits that look identical for both makes.
   / Ford 1920 3 point lift oscillating #5
1920 has a gear driven hydraulic pump and has no reciprocating piston.
JC,
do you think that I just need to replace the hydraulic pump or could something else be causing this.
   / Ford 1920 3 point lift oscillating #7
when you say oscillates it has to follow a frequency. does it happen at any given lift point? does it happen as max lift? if the pump was bad completely then lift arm would not come up. I'm thinking it might be max height lift adjustment, pressure relief mechanism failure or a check valve at the lift cylinder head causing it to burp( lose pressure and drop) and right away pump building pressure raising the lift arm. Need a more detailed description to may be pin point the problem better.
JC,
   / Ford 1920 3 point lift oscillating #8
a massey 40 and Nh 1920 are so different that virtually nothing will cross over...
   / Ford 1920 3 point lift oscillating #9
i think you need to stop guessing and going off on tangents like repalcing the pump and focus on getting a service manual and trouble shooting the issue before you spend way too much time and money on this.
does the lift drop when you shut the machine off?
is there a point in the positiuon control travel that the oscilations stop?
we are looking for control valve and cyl / piston realative positions.. and condition of hte oring / cyl bore.
there are other possibilities like check and or safety /relief valves too.
I'd be the first to admit I don't know jack about this, don't mind trying anything, the oscilations accur at any height, 1/2 way up, all the way, doesn;t matter, the lift arms come right up but wherever yu stop the lift the oscilations start, might ought to invest in a maint. manual
t
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
59in Tooth Bucket (A51573)
59in Tooth Bucket...
KMC 5610 LOT IDENTIFIER 33 (A53084)
KMC 5610 LOT...
Husqvarna 440 Chainsaw (A51573)
Husqvarna 440...
UNUSED CHERY INDUSTRIAL 10' - 18 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
