Ford 1910
/ Ford 1910 #1
toddbailey
south carolina
nh 3930, ford 1910, farmall super a, allis chamlers b
i have just gotten a 1910 and we are getting around to changing fluids and filters before we put it to work, i need to know how to change the oil for the injector pump a diagram would really help out a lot!
/ Ford 1910 #2
Betchur service manual has one!
soundguy
/ Ford 1910 #3
Link below will generally help you. You have a 3 cylinder vs 2 Cylinder depicted in the link below and that should not matter on oil change. Procedure is the same. The oil in the injector is dedicated to injector pump only on 1000 series (Japanese shibaura) to the best of my knowledge, and is not part of the crankcase oil. Use the same oil for injector pump assembly as you use for the engine.
JC,
http://www.tractorbynet.com/forums/nh-buying-pricing/84052-injector-pump-oil.html
/ Ford 1910
that is a great help, we didn't want to use it to much without changing injector oil and didn't want to wait until the manual came in!
/ Ford 1910 #5
Hello all,
what oil are you using in the engine? Castrol Tection 15W-40 is what i planned on using would that be ok to run in the injection pump as well?
Thanks,
Mike
/ Ford 1910 #6
I use Dino Rotella 15W-40 as well as NH Master Gold SAE 15W-40. I don't reckon I can tell the difference. My tractor is not worked heavily and I change oil and filter every 50 hrs.
JC,
/ Ford 1910 #7
JC,
thanks for the info, have you ever changed the oil in the injection pump? Also what is the oil filter number that your using?
Thanks,
Mike
/ Ford 1910 #8
JC,
Thanks,
Mike
Hi Mike,
Yes I have. It is essential to change the oil in the injector pump . Please look at the link below. Bear in mind that mine is 2 cylinder Jobby vs. your 3 cylinder rig, but the concept and method is exactly the same.
JC,
http://www.tractorbynet.com/forums/...52-injector-pump-oil.html?highlight=ford+1700
This for 1700, have not checked if it works on 1910.
/ Ford 1910 #9
JC,
Great PIC!yep bought the tractor with 85 hours on it and just want to make sure that everything is taken care of properly.. What about the tranmission and hyd fluid? Had some one tell me that it takes 5 gallons of hy-tran fluid. How do you tell if there is enought fluid in the tranmission?
Thanks for all fo the help!!!!!!
Mike
/ Ford 1910 #10
JC,
Mike
Yes, it take whole bunch of Transmission fluid. I bought Mystick from TSC that meets or exceeds Ford 134 about $35 if I remember it right. I have got the skinny on the whole procedure. I'd recommend you to put your seat belt on, get yourself a Thermos of black coffee or tea in my case.:D:D and start reading.
JC:)
Ps. there is a dip stick on the top cover of transmission that tells you the level, but it will not tell your everything.
Information below does answer your question but has a lot of extra inf as well. It is a good read.
http://www.tractorbynet.com/forums/new-holland-owning-operating/88973-sos-i-have-my-first.html
http://www.tractorbynet.com/forums/new-holland-owning-operating/90819-my-f-1700-testing-my.html
/ Ford 1910 #11
JC,
Mike
If you want to take care of your new tractor properly, why not invest the $20 in an operator's manual? Item number 42191010.
https://www.newhollandtechpubs.com/default.asp
Of course you may be correct, but the chances of buying a 20+ year old tractor with 85 actual hours on it is quite remote.
/ Ford 1910 #13
Thanks for the info, I'll take a look at the filter thats on the tractor and do a cross reference. I'll look at getting the manual for the tractor also that would be a great help!
JC,
Thanks for all the info and links they really helped!!!!
Mike
/ Ford 1910 #14
Wix filters and napa filters are the same (I believe). I looked up all the filters for my ford 1710 on the wix link provided in the thread and they are the same as I got from napa. The NAPA store here had a book and was able to look up the proper filters for me. I'm sure the NAPA store there can to. That is if NAPA is nationwide.
/ Ford 1910 #15
I second that. The operator manual for the Ford 1910 explains how to perform all of the requirement maintenance procedures.
I am not sure that I would spend any time trying to crossmatch filters and things -- just go to the New Holland dealer and buy the right stuff until you get real comfortable with the parts.
I am not sure how you "change" the oil in the injector pump -- I think you are just supposed to add more to replace what gets lost during engine operation. You can use the same oil that you use as motor oil.
The transmission and the hydraulic system use the same fluid. My 4x4 1910 holds about 29 quarts, which is little over 7 gallons. The procedure is to warm up the fluid (harder than you might think) and drain it -- there are three different drain points on the 4x4. You should drain/replace the hydraulic filter, too.
Once again, go buy the operator manual and all of the regular maintenance items will be covered, including the schedule and procedures. You can find one on the Web, or at New Holland.
/ Ford 1910 #16
I second that.
No oil gets used up. You only loose oil if shaft seal are damaged or pump body has a crack. Injector oil is separate from crankcase and not shard. procedure is simple and was explained before. Please look at the link below.
JC ,
http://www.tractorbynet.com/forums/...injector-pump-oil.html?highlight=injector+oil
/ Ford 1910 #17
JC ,
Another quote by JC-jetro in a separate reply "This for 1700, have not checked if it works on 1910."
That actually is more accurate than linking info on a 1700 and presuming it applies to a 1910. It does not. Computer Guy's post is accurate for a 1910. Once again, an operator's manual for the model in question typically has correct info.
/ Ford 1910 #18
I stand corrected once more by Rick:), However on the link that I posted, if you refer to post #9 I did have a scan of procedure for 1910 and it "does say on 1910 the oil in the injector is common with crankcase". Only, I could not remember it.
My bad:)
JC,
I'm glad I use provisos when I'm not sure.... usually I mean:eek:
/ Ford 1910 #19
Some alternates for the WIX 51512 oil filter:
Fram 2870A also fits, and the WIX 51773 works- it is the same on filter gasket size and threads, with a longer body (6.9 inches) and more filter area.
Just something to think about.
204549 (A52707)
204549 (A52707)
2017 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2017 Ram 2500 4x4...
Case-IH 370 Steiger (A57148)
Case-IH 370...
2017 Infiniti QX60 SUV (A59231)
2017 Infiniti QX60...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
