Ford 1910 hydraulic manifold
   / Ford 1910 hydraulic manifold #1
dirk919
muskogee,ok
ford 1910, ford 8n
Hey guys, I have a Ford 1910 with 770 loader. The tractor has a hydraulic manifold block in front of the brake pedal that can switch the hydraulics from the loader to the 3pt. One of the quick connects on the manifold for the loader connection has been leaking so I ordered new couplers. Changed them out and now the loader won't work. If I turn the manifold to run the 3pt I have hydraulics and everything sounds fine. However, if I switch it to run the loader the tractor bogs down and a hissing sound comes from the manifold. All I did was switch the couplers so I'm baffled what the problem is. Debris in the manifold now? Please help. Thx.
   / Ford 1910 hydraulic manifold #2
A guess but did you change both the male and female halves of the quick connect.
It sounds like fluid is being blocked at the quick connect.
Either because the quick connect is not completely engaged or you have mis matched parts.
With the pressures involved in a hydraulic system debris blockage is unlikely.
Dave M7040
Yes I did. It does this regardless of whether the loader is hooked up or not.
   / Ford 1910 hydraulic manifold #4
Take a look at the feedback linkage. Might make sure the rod isn't hanking up or the ajustment nuts didn't come loose. Check you manual for adjustment and how to set the upper most travel.
More info coming soon! (A48081)
More info coming...
6000LB Axle (pair) (A49251)
6000LB Axle (pair)...
2005 Ford Freestar SE Minivan (A48082)
2005 Ford Freestar...
Rock Rake Rail w/ Tines (A49251)
Rock Rake Rail w/...
2020 MITSUBISHI OUTLANDER SPORT (A48992)
2020 MITSUBISHI...
Pallet Fork Frame (A47371)
Pallet Fork Frame...
