ford 1910 hydraulic issue
   / ford 1910 hydraulic issue #1
farmguy6
oakdale, ct
ford/1910
I have a ford model 1910 and the hydraulics have slowly deteriorated to the point where the bucket no longer moves and neither does the 3 point hitch lift arms. When I changed the oil filter, things seemed to work fine for a short time and then quickly deteriorated again. There is some sign of water in the hydraulic oil. I'm looking for suggestions to what I should first look into before I get in too deep. Thank you.
   / ford 1910 hydraulic issue #2
Sounds like something plugged your new filter. I would probably pull that new filter out and examine it closely.
   / ford 1910 hydraulic issue #3
I agree with oldtractorfixer. Pull the filter off, look down at the housing for anything that might be blocking the passage. My 1910 hydraulics slowed down for no reason over the course of about 2 weeks. When I took the filter off, I found some silicone sealant laying in the housing. I removed the silicone and I was back in action.
   / ford 1910 hydraulic issue #4
I just reread your post. Some Hydraulic filters will plug from water. Sounds like time to change the oil as well as the filter.
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A48836)
2007 International...
2011 Ford F-250 Pickup Truck (A46684)
2011 Ford F-250...
Galvanized Pipe (A49251)
Galvanized Pipe...
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
ClarkLift 2,400lb Propane Forklift (A49346)
ClarkLift 2,400lb...
